Author Topic: DB9 connector with locking mechanism  (Read 8499 times)
Offline motocoderTopic starter
  • Electrical Engineer
« on: August 07, 2015, 01:08:26 am »
I am trying to locate the connector / connector housing and hardware to make a cable with an end that mates to the DB9 connector in the picture below. The connector itself is a standard DB9 male, but notice that instead of screws it has some sort of pin to which something latches. I thought it was the "Slide Lock" mechanism sold by Conec, but I ordered two Slide-lock equipped housings from DigiKey, but what I got will not latch onto that. I might just be missing a piece, or could be the entirely wrong thing.
Can someone who is familiar with this please help me locate everything I need to build a cable that attaches to this?
Thanks
Offline C
Re: DB9 connector with locking mechanism
« Reply #1 on: August 07, 2015, 02:18:36 am »
Could it be the one on page 151  Adobe says page 62
http://www.te.com/usa-en/product-5745584-3.html#pdp-docs-features
C
Online Vgkid
« Reply #2 on: August 07, 2015, 02:32:49 am »
That does look like it.
I assume you do not have the matching power connector?
« Reply #3 on: August 07, 2015, 02:36:01 am »
Yes, I agree that it looks like it. Maybe I should contact TE and ask them to send me a complete list of parts.
I don't have the mating connector to compare with. This connector actually supplies power to the device (no idea why they are using a 9-pin connector designed for low amperage signals to a device that draws 48W). So what I have right now is just a DB9 connector that's just resting in there, and I've already knocked it out several times while working around the area where that connector is.
« Reply #4 on: August 07, 2015, 03:00:45 am »
I sent a question to TE Connectivity via the form on their web site.
Thanks everyone for the help. If someone has direct experience with this connector, I would appreciate if  you can add detail or confirm if we're on the right track here.
Online MarkF
« Reply #5 on: August 07, 2015, 03:09:39 am »
Is replacing the pins with the more common screws an option?
Offline C
« Reply #6 on: August 07, 2015, 03:17:18 am »
Think the pins are rated to 1 amp
5 ground 4 power 0.5 per pin
Would guess that only mounting bolts are different.
From what I have seen that style holds better then the slide lock that does both sides at once
C
« Reply #7 on: August 07, 2015, 03:20:31 am »
I think so, Mark. That will be my fallback if I can't get this slide lock thing figured out.
« Reply #8 on: August 07, 2015, 03:21:04 am »
C
Yes, except they only use 2 of the pins - one for +24V, one for GND.
Online Vgkid
« Reply #9 on: August 07, 2015, 03:29:31 am »
I couldn't figure out why they chose that as well. I can take a picture of the mating connector in a few days. Currenty on vacation.
« Reply #10 on: August 07, 2015, 03:31:20 am »
That would be much appreciated.
Offline helius
« Reply #11 on: August 07, 2015, 03:39:45 am »
My eyes could be deceiving me, but that looks quite a bit like the slide lock used for Ethernet AUI.
http://www.aim-ele.co.jp/products/aui/images/aui-big.jpg
Retention is not all that good, and it has the downside of requiring you to reach between the connector shell and the panel to operate.
You can also see that the locking piece fits over a regular D-sub socket and is retained with screws.
[But I should point out that not all D-sub pins are created equal and some carry higher current than others.]
« Last Edit: August 07, 2015, 03:43:05 am by helius »
Offline piranha32
    • random ramblings of an engineer
« Reply #12 on: August 07, 2015, 03:40:33 am »
You can buy the lock as an accessory for DB9 connector: http://www.digikey.com/product-detail/en/160-009-002R031/160-09SLA-ND/1008073 but I can not find matching shell. You can also just ignore the lock and use DB9 connector without locking.
Online Vgkid
« Reply #13 on: August 07, 2015, 03:48:12 am »
Will do, It is strange considering that both boxes use several amps. I will also try to see if any of those are different when hooked into the main distribution box.
« Reply #14 on: August 07, 2015, 05:06:18 am »
I've been wanting to ohm out the connector to see if any of the other pins are connected, but I don't want to disconnect  the thing right now as the OCXOs seem to finally be aging nicely.
Online Vgkid
« Reply #15 on: August 07, 2015, 05:33:17 am »
I will check mine, the internal ocxo has rather crummy specs.(I narrowed it down to 2 possible choices VectronC4710, or MTI-250. I unhooked it as the gps stopped locking suddenly after mooving it(bad connector)
Oh well I'm building a Shera gpsdo, and contemplating another gpsdo.
Vectron
http://www.vectron.com/products/ocxo/c4710.pdf
MTI
http://www.mti-milliren.com/pdfs/250.pdf
http://www.mti-milliren.com/prodDetail/250/253_mech.html
« Last Edit: August 07, 2015, 05:47:08 am by Vgkid »
« Reply #16 on: August 07, 2015, 08:24:01 pm »
I got a reply from TE Connectivity today. They sent me several assembly diagrams, but the most useful document is the assembly instruction sheet. I am attaching that here now and will follow up with part numbers once I have a confirmed working set-up.
Online Vgkid
« Reply #17 on: August 08, 2015, 10:01:23 pm »
 The mating(cable side) is totally blank, the box unit has these part numbers.
241A12600x-s1 conec
« Reply #18 on: August 11, 2015, 02:02:04 am »
Ok, these slide latches work:
TE Connectivity Part Number: 5206942-1
DigiKey Part Number: A33703-ND
http://www.digikey.com/product-detail/en/0/A33703-ND
Each kit comes with latches for both sides of a single connector. The housing ears must not be too thick for the screws to go through. I ended up using the TE Connectivity housings that don't have any ears. I'm not real happy with those, but everything did fit, and the connector can't fall off anymore.
