Author Topic: Dual LM317/337 supply sequencing  (Read 2267 times)
Offline bdiviTopic starter
  • Country: bg
« on: February 19, 2015, 10:28:13 am »
Hello,
I am building a bench power supply and I am using +/- 15V auxiliary supply for the high side control circuitry. That aux supply is based on LM317/337.
As I am finalizing the project it turned out that were are random spikes from the main supply when I turn it on because of the aux supply - in order to fix that I need to delay the +15V rail by 100-200ms relative to the -15V rail.
Any ideas how to do that without going digital ?
Offline MrAl
Re: Dual LM317/337 supply sequencing
« Reply #1 on: February 19, 2015, 04:46:37 pm »
I am not entirely sure what problem you have having, but it sounds like a large capacitor might work.
Maybe you could explain the problem a little better too.
Offline void_error
  • I can transistor...
« Reply #2 on: February 19, 2015, 05:13:51 pm »
LM393. Half of it is a comparator to detect that the negative rail has reached 15V, the other half a delay circuit. Use a TL431 or a zener as the reference for the comparator. Some extra transistors might also be needed.
Trust me, I'm NOT an engineer.
Offline C
« Reply #3 on: February 20, 2015, 05:04:24 am »
see figure 36 in
ti's datasheet
http://www.ti.com/lit/ds/symlink/lm117.pdf
C
  • Country: bg
« Reply #4 on: February 20, 2015, 07:55:56 am »
see figure 36 in
ti's datasheet
C
That would not work for me - it is slow start from 1.25V and not from 0. Should be something that do not rely on the output to charge a capacitor.
