Author Topic: Long lead time on X1 Capasitors  (Read 7659 times)
Offline BlochTopic starter
« on: April 07, 2011, 01:32:43 pm »
Hi
Do you know there i can buy 100nF X1 760vAC size is not important. Like http://www2.mouser.com/ProductDetail/Kemet/PHE845VD6100MR06L2/?qs=sGAEpiMZZMvQAn3cSZoTr5GrNz0LKpDovCUxxaM%252bXts%3d
The reason I ask here is that i nead them now and All the places i do know have lead times between 26 and 52 Weeks !!
Regards
Lars
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
Re: Long lead time on X1 Capasitors
« Reply #1 on: April 07, 2011, 01:40:42 pm »
Farnell has these http://tinyurl.com/3up2n69
Re: Long lead time on X1 Capacitors
« Reply #2 on: April 07, 2011, 01:48:56 pm »
Thanks
But I do need a Rating of 760Volt AC.
And i cant see that on the list you did give me
Regards
Lars
Offline Zero999
  • 0999
« Reply #3 on: April 07, 2011, 05:45:32 pm »
Can't you put two 400V capacitors in series?
« Reply #4 on: April 08, 2011, 08:45:09 am »
It's not a perfect solution. But it seems to be the solution this time.
I wonder why everyone's stock has gone to zero and firms are up to six months to do the next batch ?
Regards,
Lars
Offline Zero999
  • 0999
« Reply #5 on: April 08, 2011, 04:02:30 pm »
Just another thought, you probably want to use 440V capacitors. if you're going to put them in series, the tolerances could mean the voltages across one of them is >400V so go for 440V of more as an insurance policy.
Offline Rufus
« Reply #6 on: April 08, 2011, 04:59:45 pm »
X? capacitors are very conservatively rated. Some manufacturers closer to what they can stand, others just call them 250vac for their intended application.
Your 760v capacitors are tested at about 4.2kv dc, one of the capacitors in the Farnell list for example
is rated at 275vac and tested at 3.4kv dc. So your 760v capacitor is rated at 2.7 times the voltage but only tested at 1.2 times.
Depends on your application but you might be reading more into that 760v rating than is really there.
Offline Zero999
  • 0999
« Reply #7 on: April 08, 2011, 05:24:02 pm »
Yes, didn't think of that but I thought the whole point of X2 capacitors was that they're overrated?
Check out Y1 capacitors which will be tested to 8kV yet rated for under 500VAC.
« Reply #8 on: April 08, 2011, 06:46:57 pm »
It is hard to find the definition.
But from here http://capakor.com/product/pdf/(21)General_technical_information.pdf
?An X capacitor is used in Across-the-line applications
?In this location,a failure of the capacitor will not cause anybody to electrical shock hazards and usually will open the fuse and turn
the equipment off.
?Class Y capacitor is used in Line-by pass applications
?In this location,a failure of the capacitor will cause anybody to electrical shock hazard
X1 >2.5Kv,<4.0Kv High pulse:industrial printer,lighitng ballast or minicomputer which is connected to a 3-phase line
X2 <2.5Kv The most common class. General purose:Computer,hair dryer,FAX,hand power tool which are plugged into ordinary wall outlet.
X3 <1.2Kv - General purpose
Y1 8.0Kv  For bridging double or reinforced insulation.
Y2 5.0Kv  For bridging basic and supplementary insulation. Application:power supply used in data processing equipment.
Y3 none   For bridging basic and supplementary insulation.
Y4 2.5Kv  For bridging basic and supplementary insulation
So It is all about safety !.
And there i use them I really dont want to experiment to much.
The power lines to there they are connected are 20*8 mm  8) and a voltage 690V
Regards,
Lars
« Last Edit: April 08, 2011, 06:51:24 pm by Bloch »
Offline Neilm
« Reply #9 on: April 08, 2011, 07:05:51 pm »
They also have to be able to withstand any voltage surge they might get on the mains. Hence the reason they will quite often have many kV surge ratings.
Neil
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
Offline Wim_L
« Reply #10 on: April 08, 2011, 07:50:05 pm »
This may or may not be safe. If the two capacitors are used near their maximum ratings and have different leakage, a charge imbalance can develop that far exceeds that of the ratio of capacitances of the two, and might exceed the rated maximum.
Offline Zero999
  • 0999
« Reply #11 on: April 08, 2011, 08:27:52 pm »
That's why I followed up with a post recommending 440V capacitors which should be overrated enough to avoid that problem.
alm
  • Guest
« Reply #12 on: April 08, 2011, 08:52:19 pm »
Depends on the tolerance of the capacitors, if they're +/- 20%, worst case is 60% of the voltage across the one with the highest value (assuming the reactive impedance is more significant than the leakage), or about 460VAC at 760VAC. This is without accounting for tempco or aging. I think playing these kinds of games with safety-critical components is a bad idea, you're not allowed to just use any old capacitor for a reason. If one of the X1 capacitors shorts, the other will be subjected to the full voltage until the shorted one heals (or melts/blows).
If I had to do a bodge job, I would use three capacitors in series to get some extra safety. Note that capacitance decreases if you put capacitors in series.
Offline Zero999
  • 0999
« Reply #13 on: April 08, 2011, 09:13:20 pm »
X capacitors aren't so critical as they only bridge live and neutral they only have to have functional insulation so no one will be electrocuted if they fail.The most important thing is they're flame retardant and self healing (unlikely to fail short circuit), as far as I can tell the impulse ratings are as much about reliability as anything else.
440V should be fine if the capacitors are 10% tolerance, use 470V for 20% tolerance. It's very unlikely one capacitor will be as bad as 10% under tolerance and the othy 10% over and if they're both installed at the same time, they should age at roughly the same rate sand therefore degradation should be similar too.
Offline RayJones
    • Personal Website
« Reply #14 on: April 08, 2011, 11:53:52 pm »
Is there any problem in using a few hundred K in parallel with the caps for the express purpose of load balancing?
That's what we were taught way back.
Offline PetrosA
« Reply #15 on: April 09, 2011, 02:52:03 am »
I recently read an article about long lead times for lighting fixtures here in the US. Evidently it's mostly the specialty high efficiency stuff with electronic transformers/ballasts required by new laws in commercial/industrial settings that are affected and the problem is bad. Contractors are bidding jobs and can't get the fixtures in time to meet the deadline. Supposedly the problem is that a large number of small electronic component manufacturers went out of business during the peak of the economic crisis and the big players slowed down production to the point where now they can't keep up. Some suppliers claim the lead time is better than it was - down from 8-12 weeks to 6-8 weeks, but still way too long for bid projects.
I don't know if you'll be able to read this without being logged in, but here's the article:
http://ecmweb.com/lighting/ballast-shortage-20110201/
I miss my home I miss my porch, porch
« Reply #16 on: April 09, 2011, 03:22:34 am »
economic crisis
Thank you for the link.
First economic going to fast then slow and now faster again.
Why is that my problem  ???  ;D
Offline Zero999
  • 0999
« Reply #17 on: April 09, 2011, 08:05:32 am »
That works better with DC than AC. For DC, the divider just needs to draw a bit more current than the leakage through the capacitors so very high value resistors will do. With AC, the resistors still need to have a lower impedance than the capacitors but it's much lower with AC flowing through them. In this case 220nF capacitors (required for just over 100nF when connected in series) have an impedance of 14.5k at 50Hz so resistors with and lower value would dissipate too much power.
alm
  • Guest
« Reply #18 on: April 09, 2011, 12:01:59 pm »
You'll also have to make sure that your resistors are specified for the working voltage and transient voltage, and will fail safely.
