Author Topic: Looking for something like a MAX40200 in a SOT-23 case  (Read 1099 times)
Offline perdrixTopic starter
« on: February 22, 2018, 11:19:18 am »
The MAX40200 ideal diode current switch looks almost ideal for a problem I wish to solve, but (there's always a but) what I'm looking for would have two of them configured in a SOT-23 format just like the BAT54C which I'm looking to replace in a dual supply steering application without changing the PCB.
https://www.maximintegrated.com/en/products/analog/amplifiers/MAX40200.html
Does anyone know of a product like that?
Thanks
Offline SiliconWizard
Re: Looking for something like a MAX40200 in a SOT-23 case
« Reply #1 on: February 22, 2018, 03:16:44 pm »
So-called ideal diodes usually need a reference potential (GND), so I doubt you can find a dual ideal diode in a 3-pin package.
One option would be to design a small adapter (provided that you can have access to GND nearby and that there is enough available space on your board).
If a 2.5V to 5.5V operating range fits your requirements, the LTC4413 could be a match. You'd still need an adapter.
« Reply #2 on: February 22, 2018, 04:41:36 pm »
Thank you,
I just hate those DFN surface mount ICs.  The LTC4411 http://www.linear.com/product/LTC4411 might fit the bill with some extra components.
I wish they made the 4413 in a SOT type package, as I'm sure I could find a ground nearby.
Does anyone else have any suggestion.
Dave
