Author Topic: Problem of surge currents in PFC's sense resistor (LT1248 & LT1249)  (Read 1106 times)
Offline ocsetTopic starter
The LT1249 and LT1248 are both CCM PFC controllers. They are very similar chips.  :clap:
Why is it that the LT1249 datasheet,  on page 10, recommends a surge current bypass circuit (three diodes)  for the sense resistor , but the LT1248 makes no mention of any need to protect  from  such surge currents?  :-//  (eg the rush of current through the sense resistor if the PFC is switched on at Mains peak)
Also, The LT1248 leaves one with a choice of what maximum sense resistor voltage to employ…but what is the maximum?  :-//
LT1249 datasheet:
http://cds.linear.com/docs/en/datasheet/1249fbs.pdf
LT1248 datasheet
http://cds.linear.com/docs/en/datasheet/1248fd.pdf
 :scared:   :horse:   ................  8)
Re: Problem of surge currents in PFC's sense resistor (LT1248 & LT1249)
« Reply #1 on: November 18, 2017, 11:37:20 pm »
Thanks, do you suspect that the LT1248 doesn't need a series diode chain bypassing its sense resistor for those current surges?
« Last Edit: November 19, 2017, 11:44:04 am by treez »
« Reply #2 on: November 19, 2017, 11:50:34 am »
Hello,
100A surge on a 0.2R shunt is 20V, 20V over 4k is 5mA. I don't think 5mA is going to kill the chip.
Thanks, the thing is, our sense resistor is 1.2 ohms…so that’s 120V when a 100A surge flow through it.  With the 4k resistor going into the MOUT pin, that’s then 30mA  flowing in the chips ESD diode…that’s a lot.
Do you think we in fact must have  either a zener or a diode chain across the sense resistor?
Why doesn’t the datasheet mention this?
The attached shows the issus...LTspice sim and pdf schem attached.
