Author Topic: 3.5mm headphone jack 3p/4p temperature sensor standard?  (Read 1291 times)
Offline mairoTopic starter
« on: June 03, 2020, 05:06:23 pm »
Hi all,
Is there a standard for the pin-out of a  3.5mm headphone jack 3p/4p when used with temperature sensor, particularly in the power wiring? Mainly 1-Wire based digital sensors, but if there is something for analog ones (e.g. MCP9700 based ..), I am also interested to know.
The only information I found was from iTead on some Sonoff probes:
https://www.itead.cc/wiki/Sonoff_Sensor_Si7021
and some tread in which the circuitry for the power seems flipped when compared to the one from iTead/Sonoff tread above:
 http://rants.dyer.com.hk/rpi/1wire.html
Thank you
Offline aix
Re: 3.5mm headphone jack 3p/4p temperature sensor standard?
« Reply #1 on: June 04, 2020, 06:17:19 am »
It looks like the first link uses a 2.5mm, not a 3.5mm, connector.
I've seen meat cooking probes also use a 2.5mm connector for the thermistor, but I'm guessing that's not the type of temperature sensor you're after.
