Author Topic: Max9611 high internal temperature  (Read 550 times)
Offline prudencioTopic starter
  • Country: br
« on: March 18, 2019, 11:31:39 pm »
Hi Everybody
Does anyone have been using MAX 9611  CURRENT SENSE?
The internal temperature has increasing up to 122 degrees celsius when I increase the input voltage to device with 0 current.
see below the measurements:
As I increased the input voltage, the internal temperature rose.
input voltage RS+ pin2------4,067v current =0 intrenal device temperature 39,30 celsius
input voltage RS+ pin2------5,048v current =0 intrenal device temperature 46,08 celsius
input voltage RS+ pin2------6,044v current =0 intrenal device temperature 55,20 celsius
Tkanks a lot, best regards
« Last Edit: March 19, 2019, 12:28:43 am by prudencio »
