Author Topic: Power supply for Class D amplifier  (Read 561 times)
Offline Adgj533Topic starter
« on: March 19, 2019, 03:40:35 am »
Hello guys, I am trying to build a class D amplifier at home on a breadboard(schematic attached). I am going to do this on a PCB as well but I used a breadboard to test it and see how it works etc. My question is I am having trouble connecting the power supply to this. I built the power supply circuit (2nd schematic) and I am not sure how to connect it to my power supply. The PSU I have is this: (the model I have is 3 A in series and 6A in parallel, this model has higher current but everything else is the same):
https://www.amazon.com/Precision-Triple-Output-Linear-Quadruple-Display/dp/B00B03X90Y
I used + terminal of one side and put the - to the ground to get +30V and the other side I did the opposite to get -30V. Is that how I am supposed to do it? Also my PSU can only do 3 Amps max in series, is that enough to power this amplifier?
Thanks for taking the time to read this.
Any help is greatly appreciated
« Last Edit: March 19, 2019, 03:44:25 am by Adgj533 »
