Hi all,
I've recently been tearing down various ATX PSU's for use in other applications, and after cutting down a few forests worth of wires, I've been wondering why all the parallel connections are needed at all?
I understand that the motherboard connectors have multiple pins that need power to be delivered, but why use multiple grounds and power pins in the first place?
Surely it would be more economical and 'clean' to simply use less wiring at a thicker gauge if resistance is the issue...
Cheers,
Posh
