Hola mate,
to be honest, it was tested in a sunny yard, but we could see no light on the display at all. Am returning on Monday and will put it indoors to see if we get at least a glow.
The situation, is that this unit is located 2 hours travel (each way) and I have to transport an inverter and transformer each time, just to test it! The owner wants it sold, however it was totally dead and being a complex instrument no-body had wanted to buy it, so I offered to try to get it to at least turn on.
That much we did, but within thirty seconds an 800K resistor on the Deflection Amp (located at the base of the CRT) started smoking, so we switched it off and pulled the board. No time to test any internal voltages.
The only damaged component I found on the Defl' Amp was the LM318, so that was changed and all poor solder joints were touched up ready for the Defl' Amp to be reinstalled.
My basic - and very rusty - understanding of CRT technology (learned 30 years ago at college) left me thinking that perhaps the CRT display needed the Defl' Amp signal to generate anything at all but I have been reading up and now have a clearer understanding of CRT systems.
Yesterday I also found the PSU diagram with the correct output voltages (which I didn't have before) so will check these first before I reconnect the Amp and turn the instrument back on. Perhaps I was a bit carefree in assuming all the PSU output voltages would be good, after the probe connection pin readings came back spot-on (+15v -15V +5v). Perhaps one of the output voltages is now too high?
There is also a small HV board which sits alongside the CRT at 90 degrees to the Defl' Amp, although I am not too sure as to how to go about testing this. I am reading the relevant part of the manual today in order to clarify this.
We have to remember this unit has been sat in a dusty storeroom for 7 years and who knows when it was last used before that? It
is in good condition. Super clean inside. Just needs some tlc.
Any input you can give will be well appreciated.
Cheers,
Gazucha.
