Author Topic: DE-5000 LCR meter strange behavior  (Read 2150 times)
Offline alexoTopic starter
« on: February 27, 2017, 02:06:38 pm »
I measure 100nf ceramic disk caps with a DE-5000. It starts by showing a value of around 65nf and the value indicated keeps increasing over 90 seconds or so to around 85nf.
I wonder if anybody has some explanation. My other LCR metter is rock solid from the beginning.
Offline TimFox
Re: DE-5000 LCR meter strange behavior
« Reply #1 on: February 27, 2017, 02:15:56 pm »
What type of ceramic part is this (X7R, Z5U, etc.)?
« Reply #2 on: February 27, 2017, 02:55:23 pm »
No idea. I bought them on eBay - 1000 pieces. There is a small slip saying " Ceramic disk capacitors, 104PF, Tol +-80/20%, wvdc 50V and T.C. Y5V
I tried with other ceramic caps as well and I saw the same behavior. Also, I tried diff frequencies for the meter.
Offline TimFox
« Reply #3 on: February 27, 2017, 05:02:31 pm »
"Y5V" is the type of capacitor.  These are very non-linear, but I don't know why they would behave better on your other meter.
Can you try a film capacitor (polyester or polypropylene) of the same value on your suspect DE-5000?
« Reply #4 on: February 27, 2017, 06:07:07 pm »
Doesn't do it at all with polystyrene caps. Rock solid. I tried quite a few values as I have about one cubic meter of those in various values , all 500V .
I really wonder what's going on here.
Offline Nermash
« Reply #5 on: February 27, 2017, 06:25:28 pm »
My DE5000 does exactly the same thing with cheapo 100n ceramic caps.
« Last Edit: February 27, 2017, 06:40:57 pm by Nermash »
The following users thanked this post: alexo
Offline Conrad Hoffman
    • The Messy Basement
« Reply #6 on: February 27, 2017, 07:53:14 pm »
You'd have to put a scope on it. Those high k ceramics can have huge temperature coefficients, but also surprising voltage coefficients. If the meter changes its excitation voltage for some reason, the indicated value will change. I also assume you don't have your warm fingers holding the cap?
« Reply #7 on: February 27, 2017, 08:05:18 pm »
I'm not touching the caps while being measured and I pick them up with tweezers. I also left one in like 30 minutes with the meter off to avoid exactly that sort of issue.
Beats me how these sort of caps can be usable for anything.
« Reply #8 on: February 28, 2017, 06:38:05 pm »
Anything? Well, they're useful for making a profit for the manufacturers! Very high k ceramics let you get a lot of capacitance in a small space, and sometimes keeping things small is the highest priority.
