In its “Microscope Components Guide”, Olympus shows the most important parameters that are usually shown on objectives. The first line shows the name of the objective. The second line shows the magnification factor and the numerical aperture. Letters at the end of the second line indicate special variants.
The infinity sign in the third line shows that the lens is infinity corrected. This means that the light rays leave the lens in parallel. Most modern lenses are infinity corrected. The following number stands for the cover glass thickness, which is included in the calculation of the optics. In biology, a cover glass is usually placed on the object. Here the number 0 indicates that you should work without a cover glass in order to obtain an optimal image. The last number is the field number. It indicates the diameter of the image in the eyepiece.
If a lens is designed for use with an immersion liquid, this is usually printed on the lens. Sometimes the working distance is also printed. A colored ring makes it easy to see the magnification factor at a glance. Certain colors are assigned to common magnification factors.
The magnification factor often seems to be the most important parameter of an objective. However, as long as the camera sensor offers sufficient resolution, the numerical aperture is much more important. The NA value defines the resolving power of the lens. The “Microscope Components Guide” shows how to calculate which structures can be resolved. For an objective with an NA of 0,9 the minimal structure width is 0,37µm. The resolving power also depends on the wavelength of the light. Green light was used in this calculation. With red light, the resolution drops to 0,47µm.
In the “Microscope Components Guide”, Olympus also explains the meaning of the designations of its objectives. The M as the first letter indicates that it is a metallurgical objective, i.e. designed for coaxial illumination. LM and SLM lenses offer increased working distances. LC stands for special variants that can be used for reflected light microscopy through glass layers.
PL or plan means that the objective projects an image without curvature. If the image is only viewed directly, without a camera, a certain amount of image curvature is not a problem. However, when using cameras and if you want to create panoramic images, the images must be as distortion-free as possible. The following letters show how well the chromatic aberration has been corrected. This is followed by the magnification factor. The last letters stand for special properties.
The following images are from the standard cell ASIC U1525FC007, which was manufactured with a minimum structure width of 1.5µm (
https://www.richis-lab.de/logic27.htm).
The UPlanFLN 4x 0,13 objective offers the smallest magnification factor of the objectives examined here. It can image an area of 5,6mm x 3,7mm. The die of the U1525FC007 is very large with an edge length of 7,5mm. ICs that are not so large can be completely imaged with the UPlanFLN 4x 0,13. For larger objects, a panorama must be created. In this case, 6 images would be necessary for the U1525FC007. Objectives with such small magnification factors usually also have a small numerical aperture. Mathematically, the value 0.13 can only resolve structure widths of 2,6µm (wavelength 550nm).
The UPlanFLN 4x 0,13 is actually a biological objective, i.e. intended for transmitted light microscopy. However, no optical weaknesses can be seen in reflected light microscopy. Low magnification factors usually offer a large working distance. Here it is 17mm. The depth of field is also relatively large with 16,27µm. The preceding U in the designation shows that this is a revised version of the objective.
The UPlanFLN 4x 0,13 provides good overview images. However, if you want to view a single standard cell, the resolution is not sufficient. At full resolution, there is one pixel for 800nm on the die.
The LMPlanFl 10x 0,25 BD is an objective with a large working distance of 21mm. It is optimized for use in metallurgical microscopy and also allows darkfield illumination. With a magnification factor of 10, the area that is imaged shrinks to 2,3mm x 1,5mm. If you want to capture the entire die, 24 images are required. At the same time, the focal plane shrinks to 18µm. The NA value of 0,25 is not particularly high for a lens with a magnification factor of 10. This is due to the optimization for a large working distance. The objective allows structure sizes of 1,3 µm to be resolved.
The standard cells are now more clearly recognizable. The minimum structure width of the process is 1,5 µm. It is already possible to analyze the circuit. However, in areas where several structures overlap, the image is still unclear.
The LMPlanFlN 20x 0,40 BD is also a lens with a long working distance, which in this case is 12mm. The magnification factor is 20 and the NA is specified as 0,4. With an imaged area of 1,1mm x 0,8mm, at least 70 images are required to fully document the die. The resolution drops to 0,84µm. However, the focal plane also shrinks and is now just 6,1µm.
With the depth of field of the LMPlanFlN 20x 0,40 BD, it is difficult to align the die sufficiently flat. With this process, you can just take pictures without focus stacking, although the image quality is already borderline in this respect. The top left corner shows a certain amount of blurring. This could be due to imperfect alignment. However, it is also possible that the objective has a weakness there. If you want to create a panoramic image with this image quality, the blurring can already lead to artifacts and make circuit analysis more difficult. Instead of performing focus stacking, you can also crop the image and only use the sharp area. However, this reduces the area that can be imaged at once even further.
With the available depth of field of 6,1µm, you have to bear in mind that the structures of the integrated circuit have a certain height. A metal layer may well be 1µm thick. The oxide layers between the wiring levels can also be 1µm thick. This quickly leads to total thicknesses that require focus stacking even with perfect alignment. Overall, however, the image quality is now sufficient to analyze the circuit. The two polysilicon layers are clearly visible. Assigning overlapping structures to their functions is also possible.
The magnification factor of the UMPlanFl 50x 0,80 BD is just 0,45mm x 0,30mm. This means that 442 images would be required to fully image the die. At the same time, however, a very high numerical aperture of 0,8 is achieved, allowing a resolution of 0,42µm. However, the significantly increased numerical aperture comes at the price of a small working distance of just 1,0mm.
The image section is now very small. However, the structure of the standard cells can be seen very clearly.
With the shallow depth of field of 1,3 µm, focus stacking must be carried out. If the limits are defined optimally, 14 individual images are sufficient for this circuit. Focus stacking with 14 images is not a major effort. However, you must bear in mind that the effort is multiplied. This means that 6.188 images are required to fully map the ASIC.
The working distance of 1,0 mm can quickly become a problem. If the circuit is located in a ceramic package which has side walls, there are usually collisions. Larger superstructures are out of the question anyway.
There is also a objective with a large working distance in this range. The LMPlanFl 100x 0,80 BD also offers an NA of 0,8 but allows a working distance of 3,3mm. These specifications come at the price of an increased magnification factor of 100x and a further reduced depth of field of 0,87µm. The LMPlanFl 100x 0,80 BD images just 0,23mm x 0,15mm of the circuit. This means that 1.650 images are required for a panorama. With the 17 images required for focus stacking, this means that 28.050 images would have to be taken in order to optimally image the ASIC.
The image quality is just as good as with the UMPlanFl 50x 0,80 BD, only the imaged area has been reduced.
The diagram above is taken from the article “Systematic design of microscope objectives. Part I: System review and analysis” by Yueqian Zhang and Herbert Gross and shows two important relationships. Firstly, the numerical aperture and thus the resolving power of ordinary light microscopy cannot be increased arbitrarily. The limit is 0,95. For green light, this corresponds to a resolving power of 0,35 µm. If you want to increase the NA value further, you have to replace the air between the objective and the object with another medium and thus optimize the refraction of the light. This process is called immersion. Water or various oils can be used for this purpose. The lenses must of course be designed for this. With oil immersion, NA values of 1,5 can be achieved, which corresponds to a resolving power of 0,22 µm.
The diagram also shows how critical the thickness of the cover glass is if the lens has been optimized for use with a cover glass. There are many biological lenses on the second-hand market for which this applies. With low NA values, the thickness of the cover glass is less critical. This goes so far that objectives such as the UPlanFLN 4x 0,13 do not even specify a number for the cover glass. There is just a “-”. It simply does not matter whether and which cover glass is used. At higher NA values, however, the image quality deteriorates increasingly if the correct cover glass is not used. Lenses for oil immersion are less critical in this respect, as the refractive index of oil is relatively similar to the refractive index of glass.
The Zeiss Primo Plan-Achromat 100x 1,25 shown here is a typical biological objective designed for oil immersion. Next to the NA value is the note “Oil”. This objective has some disadvantages. Although Zeiss objectives are infinity corrected, they usually still have minor optical weaknesses that are corrected within a Zeiss microscope. This results in somewhat poorer image quality in an Olympus microscope. In addition, the field of view is smaller. This means that the camera sensor is no longer illuminated in the best possible way. The working distance is 0,14mm. If you work without a cover glass, you can add its thickness of 0,17mm.
Such a lens is used as follows: You place a drop of immersion oil on the object and then move the lens into this drop. There are different oils. You do not necessarily have to use a special oil from one manufacturer. However, it should of course be an oil that is intended for microscopy. Care must be taken to ensure that dry objectives do not come into contact with the oil, as it can penetrate the interior and impair the image quality.
Even without the cover glass, the result is a very interesting image. The image quality deteriorates considerably at the edges of the image. This is not surprising given the small field of view.
In direct comparison, the Zeiss 100x 1,25 does not give you much more detail than the LMPlanFl 100x 0,80 BD. It even appears blurrier in some areas. However, it is noticeable that the vias in the metal layer are clearly different. They are shown larger and so structures can be seen in them that were not visible before.
With the darkfield illumination option, the Olympus BX51 uses BD lenses with an M26 thread. If you want to use other lenses, you usually need adapters, but these can be obtained cheaply from Aliexpress.
Here you can see a more recent integrated circuit with several metal layers. The LMPlanFl 100x 0,80 BD lens was used and focus stacking was performed. However, the shallow depth of field of the lens can also be used to advantage with such circuits, as can be seen in the following images.
The different focus levels sometimes make it easier to trace the lines or to work out special structures of one level more clearly.
https://www.richis-lab.de/Howto_Microscope_Objectives.htm
