Author Topic: Need an alternative to FFC/FPC connector  (Read 1811 times)
Offline polysomeTopic starter
« on: December 29, 2014, 07:38:05 am »
Hello I have a design for a FPGA PCB with a 60 pin GPIO breakout via a FFC/FPC connector. Its a small board and the connector is too big. Its on the underside of a miniPCIe board... what are my options ? What is a good choice for a more dense connector that is resistant to crosstalk, durable and cheap... has a near 0 height profile... and has a flex cable output ?
Offline Psi
Re: Need an alternative to FFC/FPC connector
« Reply #1 on: December 29, 2014, 07:42:18 am »
I take it soldering the FFC/FPC directly onto the PCB is out of the question?
Offline Korken
« Reply #2 on: December 29, 2014, 07:52:08 am »
Maybe use two connectors? One on each side of the PCB, then you can half the connector size.
