the link i gave is dual opamp lm139. since size is critical, thruhole is not preferable. the ltc1440 dave gave is alot better though. but thinking of it, if i want to reduce even more power, i can put pic10 in sleep mode which only use 0.1uA, and only wake up when there's signal. if i use pic, i may settle the problem right now, but with comparator, i need a good hat in analog design to get it to work. but since this is the next stage in the development, i will put this aside for a while, until when i need to translate every bit of the emf burst, for now i only need to detect the first burst, which i think comparator or pic is not necessary, i'll just use the main mcu for the purpose, or somekind of input protection, to avoid excessive voltage, although the signal will not be so high (around 5-20V max) and only for very short duration (low energy?). thanx for input guys, but a pic still in mind, maybe only for this particular project, other type of project may prefer a comparator.
the only drawback with pic i can see right now is extra programming effort, could be a problem for mass production at magnitude greater than few hundred. but i dont think a big mass production is the mission here. even if it is, i'm sure we can always resort back to comparator for the solution.
