I'm developing a battery powered circuit that powers a heating element (2.9 Ohm PCB heater) through a USB type-C connector which is also used to connect a charger. The bidirectional mosfet switch that connects battery voltage to the connector (when powering a heater) also has a polyfuse in series to protect it from shorts. I've had two polyfuses die on two of the circuits I have assembled (under normal operation, no shorts) - when heater is connected, I get only around 0.5V on my output, that should otherwise be full Li-Ion battery voltage. When not under any load, the fuse measures around 50Ohm (after plenty of time to let it cool down). One weird thing is, after desoldering one of the failed polyfuses, it started to function as expected again. This failure happened after testing the circuit for many hours (around 20h of operation). One thing I did a few days before failure is, I have coated the PCBs with a silicone compound (Kafuter K-705), to protect it from moisture. I have also used the circuit outside (in a case) in cold weather, but I don't have a clue how any of those two things could affect anything.
Is this a bad batch of polyfuses, or am I missing something? Schematic of this part of the circuit attached below.
The fuse is TECHFUSE SL1206125 bought from LCSC (part number C70164).
