Over next couple months to years, I will be experimenting with many GPSDOs; both ocxo type and Rb type. It will involve long term tests. Some of them (Especially Rb type) will take 2 Amp or more at 12 to 24 volts until warms up. My plan is to make a separate power supply unit. (strictly linear supplies) I think I'd make it 24V, 12V, and 5V output, few amps each.
Here's a question - what do you use for low voltage power connectors?
I've been using terminal strips and 5.5mm/2.1mm barrel type. But having multiple voltage will likely result in release of magic smoke. Another idea is d-sub 15pin. Fairly uncommon and each can have multiple voltages. By paralleling pins, it should be able to support few amps.
If you have good ideas, I would like to hear about it. Typically, I like building-in power supplies but for experiments and long term tests (especially), this will be costly and labor intensive.
