I have a huge 310v, 2.8A, 0.92hp COM2000 direct drive motor from a Samsung washing machine, which I am trying to salvage in the process of turning the washing machine into a cannon.
The goal is to have the motor pull back the drum (which is attached to springs at the front of the gutted washing machine) like a sling shot, with some load in the drum (watermelon, lego millenium falcon, basketball, etc.), and then release it with a trigger mechanism. It functions like a giant sling shot. Everything is already built and works, I am just trying to make it more powerful, and figuring out how to access the beautiful torque in this motor is the bottleneck for me (previously I have just been turning the motor with my hand). I also have very redundant safety precautions, and a huge private property to do this on.
My goal is to find a motor controller that can maximize the torque of the motor, to maximize elastic potential energy in the springs.
This challenge (with almost an identical motor) has been attempted to be solved before on this blog, but their solution was to just use the original controller from the washing machine:
https://www.eevblog.com/forum/projects/building-a-motor-controller-for-a-samsung-brushless-direct-drive-washer-motor/^(This is a pretty long thread, but towards the end you can find the important detail- the hall effect sensors of these motors are different from most.)
I stupidly threw away the original controller when I first took it apart, so the only option here is to build/buy a new one. I know that people have successfully used e-bike ESC's like this one
https://www.amazon.com/dp/B08HWF7MZ7?psc=1&ref=ppx_yo2ov_dt_b_product_details to drive motors exactly like this. So it is definitely possible.
I am trying to figure out:
1. The optimal specs of such a motor controller in the interest of maximizing torque (there are no limitations on available power, rpm requirements, etc.- I only care about torque)
2. Would rewiring the stator like this unlock more possible torque?
My understanding is that this lowers the required voltage and increases possible current, and more current equals more torque. Is this correct? I am trying to educate myself on what rewiring the stator would accomplish, and other general theoretical info about this problem, but all online sources about it seem to just give instructions without diving into the theory.
Thanks!
