Author Topic: XGecu TL866II PLUS programmer and GLS29EE010 EEPROM  (Read 1420 times)
Offline DarphiTopic starter
« on: September 09, 2018, 03:43:46 am »
Gday people,
I recently purchased a XGecu TL866II PLUS programmer and so far it's done everything I've needed.  But Just now I found that I can't program the Greenliant GLS29EE010 EEPROM.
Would anyone know if there is a part in the device support list that is compatible?  If not is there a way of adding the part definition?
Offline bson
Re: XGecu TL866II PLUS programmer and GLS29EE010 EEPROM
« Reply #1 on: September 10, 2018, 03:45:13 am »
PDIP-32?  If so, try pretending it's an SST‎ SST27SF010...
« Reply #2 on: September 10, 2018, 06:35:07 am »
Thanks 'bson'  I just got a reply from their support and you're correct. They said to select the sst29ee01 and then remove the tick from 'Check-ID'.  I did this an it worked a treat.
Thanks for your help  ;)
