Hello Guys, been a lurker and a long time fan of EEVBLOG.
I've been designing a circuit board that is a power supply and battery charger combo board. It's supposed to charge a 2 cell 7.4v lithium ion pack, and supply 1.8v, 3.3v. and 5v. The regulators are working fine and I can power whatever I want with them.
The problem is that whenever I connect a battery the output voltage drops to slightly higher than the battery and trickle charges at 20-30mA. It should be conditioning dead batteries at 300mA, and charging at 3A. I've tried different packs and power supplies. I've even ordered a stencil and reflowed the board to make sure my soldering was not to blame. I've checked all my connections with a meter and everything looks good. I've gotten it to work once but it was still only charging at about 1.5amps and I'm not even sure how I did it. That's when I ordered a stencil and assumed it was the soldering, turns out it wasn't.
There was actually a thread here on this website that was posted a few years ago about this.
https://www.eevblog.com/forum/projects/ltc4006-stange-mosfet-drive-signal-behavior-am-i-missing-something-basic/However he seems to have fixed the issue by adding a totem driver, which is not recommended anywhere in the data sheet as the mosfet gate pins are already suitable gate drives, so I'm not looking to add those. I also have a demo board that was sent to me after I contacted Linear Tech, and they have no kind of extra components for any special filtering or gate driving, it's supposed to be a stand alone charger.
Here's the data sheet:
http://cds.linear.com/docs/en/datasheet/4006fa.pdfHere's my schematic:
Here's my BOM:
http://www.digikey.com/short/t700b1Here's the top and bottom gate outputs of the demo board:
[imghttp://i.imgur.com/MfVjiWL.jpg]http://[/img]
Here's the top and bottom gate outputs of my board:
The major difference is that when I connect a battery to my charger the square waves become very dim and the normal 8.4v output drops to the battery voltage.
Here's the front of the board:
Here's the bottom:
You can essentially ignore the right hand side of the board beond the sw1 and sw2 through holes. The small circuit with the potentiometer is a poor mans battery sensor for the charge capacity.
I had the board fabbed at pcbway:
(Big Pic)
Assembled:
(Big Pic)
The air wire and the short across RCL were just a few of the many many things I've tried to get his to work. It doesn't look like it's an issue with the sense resistors as my traces are shorter than the demo board and adding another in parallel doesn't seem to increase the charge current. As I said before I've tried multiple IC's, packs, power sources, and more and they all seem to exhibit the same behavior so it must something wrong with my circuit, which is less likely as it's nearly identical to the demo board, or there's something wrong the the parts that I picked or the design of the circuit board.
I'm so close to just throwing this design out the windows and cutting my losses, and switching over to a max1873R. But I'd really like to avoid that as I've got so much time and money invested into this board.
You guys would be just amazing if you can help me fix my issue.
Thanks!
