Author Topic: Ebay Stirling Cryocoolers  (Read 27284 times)
Offline CatalinaWOW
Re: Ebay Stirling Cryocoolers
« Reply #25 on: March 06, 2016, 05:26:27 am »
It varies by region, for but LN2 is pretty cheap to buy.  Cheaper than gasoline.  Unless you have continuous use it buying LN2 is a far more economical way to go than to set up to produce it.
That said, the nerd coolness factor of making your own is over the top.
Offline CM800Topic starter
« Reply #26 on: March 06, 2016, 11:33:07 am »
I agree on the latter!
The main reason is that I only really want to use it periodically. I'm mostly interested in actually making the unit, mostly just messing around.
