So I have this project that's been bouncing around in the back of my head for some time now...
I finally decided to see if I can use a Teensy 4.1 module for the logic / interface side of things, but I need some guidance with selecting the pins to use on the Teensy 4.1 module.
First, power: Does the Teensy generate its own 3.3V supply or do I need to have an external 3.3V source? I would have 5V coming in from a power supply board I set up.
If I understand right, I just connect the 5V supply to pin 48 and then pull the 3.3V for three things (display, relay input pull-ups, power for the level shifter) from the Teensy?
The functions I need to allocate:
Four digital inputs (to sense relay closures)
One digital output to drive an optoisolator
Two I2C lines to drive an LCD
8 pins for a 4x4 matrix keyboard (all 16 switches in that matrix would be used)
One pin for a serial data input - this will need to be level-shifted from 5V
One pin for serial data output - this will need to be level-shifted to 5V
One pin to set send / receive mode - this will need to be level-shifted to 5V
I will also need to generate two timing waveforms, both 50% duty cycle.
One is to be a switchable 12.5kHz output, as it will be XOR'd with the serial data line (Manchester encoding)
The other is to be a continuous 2439 Hz output to time the interrupt code.
Can these be generated on-board or am I better off using a dedicated module to generate these?
