Hello everyone!
I am a space engineering student at TU Berlin and I am stuck on something.
I am working on designing a small (10cm x 10cm x 10cm) microbiology incubator that is intended to be sent to the ISS for future plantation of fungi.
The thing is, the incubator needs to maintain a temperature of 30 degrees at all times, the temperature on board the ISS is 20-24 degrees C. To increase the T, I am planning to design a circuit composed of solely resistors.
Resistors lose heat as a form of energy and this is how I calculated how much heat is lost:
Given a certain voltage V, a current I which can be obtained depending on the resistance in use, and for a heating time t:
Heat Produced =(PotentialDifference)×(Current)×(time)
The heat produced is thermal energy in joules, which can be converted to degrees C.
Now, the problem is the following:
I only need a circuit of resistors to increase the T by a maximum of 10 degrees C. I set my heating time to one minute.
But I am having a problem figuring out how this is related to the volume, I need this increase of 10 degrees to cover all the cube of 10^{3}cm.
Please help if you know how this is solved.
Kind regards,
Asma
