Features I would want in a good lead-acid battery charger:
1. Temperature compensation.
2. Charge to the equalization voltage, about 14.2 volts, and then once the current drops, switch to the float voltage, about 13.8 volts.
3. Remote sense if the charger cannot be located at the battery.
4. Input current limit to protect the power source.
