I like bench top multimeters, and I got this nice little Thurlby 1603 for about £10 on ebay a few years ago. I had to do a minor repair and now it works fine.
But, it has an LCD display. This is quite slow, small, and hard to read, so I decided to mod it to use LEDs.
I have it working (though I may modify it further to improve it), but the LEDs are too big to go in the existing case. I also wouldn't mind adding some indicator lights for things like Volts, Amps and Ohms, AC/DC etc.
Should I replace the case with a bigger one? (If so, any recomendations?)
Or should I try and use much smaller LED displays and retain the existing case?
Here's some pictures:
Thanks
steve30
