its a rigol ds1052d,its usable as is on the inverter but could be better,how do i make a mains filter?,i have a few from old bits of test gear,is it called an iec?,there metal cans about an inch wide about 2 inches long and about an inch and a half wide,would one iof those be ok?,there is room to fit the inverter inside the scope but think electrical noise will cause issues,i think its a square wave job so will be rich in harmonics!.
