Author Topic: op amp feedback loop by a open collector BJT transistor?  (Read 1500 times)
Offline awang7Topic starter
  • Country: cn
« on: June 30, 2021, 08:18:25 am »
HI All,
I'm working on a current clamp project and a schematic makes me confused. the opamp has a inverting feedback by a open drain BJT transistor parallel with a capacitor.
I assume the BJT is used as a diode to cut negative feedback but i'm not sure. why not just use a diode?
Any idea how this worked? Thanks.
attachment 1 is the circuit.
1231739-0
attachment 2 is the function diagram.
1231741-1
« Last Edit: June 30, 2021, 02:07:13 pm by awang7 »
Offline fcb
    • Electron Plus
Re: op amp feedback loop by a open drain BJT?
« Reply #1 on: June 30, 2021, 09:16:20 am »
Any number of reasons.  Could be available on the BOM (so's the 1N914 so perhaps not), could be part of matched pair with another part of the circuit, could be part of a CA3086 or similar?
Do they list the manufacturers part number for Q7?
  • Country: cn
« Reply #2 on: June 30, 2021, 09:27:28 am »
HI fcb,
Thank you for the reply. The part number of Q47 is MPSH17 from On Semi. It looks just like a normal BJT transistor.
« Last Edit: June 30, 2021, 09:32:01 am by awang7 »
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #3 on: June 30, 2021, 10:00:56 am »
It's used as a diode with a very low reverse leakage. This is fairly common, the leakage is good (pA), but the reverse breakdown is only 6 V or so.
The following users thanked this post: fcb, awang7
Offline fcb
    • Electron Plus
« Reply #4 on: June 30, 2021, 11:30:19 am »
Richard.cs makes a good point w.r.t. potentially lower leakage.
What's the part number for the diode-thing to the right of the 1N914?
Offline harerod
  • ee - digital & analog
    • My services:
« Reply #5 on: June 30, 2021, 12:14:00 pm »
awang7, welcome to the forum.
Would you mind changing the thread title into "open collector BJT transistor", please?
Bipolar Junction Transistors have Collector, Basis, Emitter, while Field Effect Transistors have Drain, Gate, Source.
Offline David Hess
  • DavidH
« Reply #6 on: June 30, 2021, 01:06:55 pm »
The transistor is operating as a fast low leakage diode to clamp the positive swing.
The following users thanked this post: awang7
Online TimFox
« Reply #7 on: June 30, 2021, 01:43:05 pm »
Also, often one will see C-B junctions (base shorted to emitter) used as low-leakage diodes with higher reverse rating than the B-E junction.
  • Country: cn
Re: op amp feedback loop by a open collector BJT transistor?
« Reply #8 on: June 30, 2021, 02:24:13 pm »
it is a current regulator CR430, I assume it is used for decrease current.
  • Country: cn
« Reply #9 on: June 30, 2021, 02:28:03 pm »
harerod, thank you for your advise. the typo is corrected.
The following users thanked this post: harerod
Offline David Hess
  • DavidH
« Reply #10 on: June 30, 2021, 02:57:28 pm »
Usually that would be my preference but the collector-base junction is slower.  I thought they might be using the base-emitter junction to also clamp the opposite polarity but that does not appear to be the case.
I think that is for limiting the output current but not the current to the integration capacitance because it is so small.
Online TimFox
« Reply #11 on: June 30, 2021, 03:18:02 pm »
I used CB diodes from low-noise audio BJTs (e.g., 2N2484 and 2N4250) in DC high-impedance analog circuits (e.g., output bounds on op amps), but I had reasonable results with CB diodes of RF BJTs (e.g., 2N918) in high impedance circuits between 5 and 10 MHZ, where the breakdown voltage of the BE junction was not sufficient for the application.
« Last Edit: June 30, 2021, 03:20:57 pm by TimFox »
Offline David Hess
  • DavidH
« Reply #12 on: July 01, 2021, 02:28:31 am »
I have used the base-emitter and base-collection junction of all kinds of small signal transistors for low leakage,  less than 10 picoamps, diodes.
