Author Topic: Opamp current buffer  (Read 3725 times)
Offline JohntronTopic starter
  • 75202
« on: September 16, 2015, 02:10:58 pm »
I've designed a voltage buffer using an opamp like so:
Current varies between the output and input circuits, but voltage is mirrored (unity gain).
How would I do the opposite with an opamp: a current buffer where voltage varies, but current is mirrored?
I know opamps have near-infinite input impedance and near-zero output impedance, so I'm not sure it's possible.
A diagram would be awesome.
Offline dom0
Re: Opamp current buffer
« Reply #1 on: September 16, 2015, 06:18:18 pm »
AKA current mirror
https://en.wikipedia.org/wiki/Current_mirror#Feedback_assisted_current_mirror
As you might see from the schematic it's just the classic op amp current source with low input impedance (current instead of voltage input).
Offline Fank1
« Reply #2 on: September 16, 2015, 10:46:20 pm »
You are in fact reading current with this circuit.
Because you have a fixed load, the 10 K resistor, the current is simply the voltage divided by 10k.
Offline sarepairman2
« Reply #3 on: September 16, 2015, 11:29:29 pm »
for high impedances you can often use the op amp in a inverting amplifier configuration with only 1 resistor to make a IV converter.
You can have
IV
VI
II
VV
« Last Edit: September 16, 2015, 11:31:22 pm by sarepairman2 »
  • 75202
« Reply #4 on: September 17, 2015, 01:27:50 am »
@dom0 ah. So the opamp can't do it by itself - transistors are required? I see how that makes sense, but was looking for a definitive answer in case I'm missing something.
Thanks! I've scrolled past that diagram multiple times, but never noticed the opamp.
Online T3sl4co1l
    • Seven Transistor Labs
« Reply #5 on: September 17, 2015, 05:47:01 am »
The traditional op-amp is a voltage type.  Meaning: the output is constant voltage, and the input-to-output characteristic is very high voltage gain and very low input current (at DC, that is).
A current type amp wouldn't be terribly hard to make or use, but I don't think it exists as a product.  There are "current mode op-amps", but these are current input only; they still deliver output voltage (so exhibit very high transconductance, instead of dimensionless voltage or current gain).  So you're kind of left making a half-assed one out of transistors and op-amps.
Seven Transistor Labs, LLC
  • 75202
« Reply #6 on: September 17, 2015, 05:59:09 am »
Perfect, thanks Tim!
Offline Phoenix
« Reply #7 on: September 17, 2015, 07:15:56 am »
You can get operational transconductance amps, that convert a differential voltage into a current e.g. LM13700. That's almost what you want...
https://en.wikipedia.org/wiki/Operational_transconductance_amplifier
