Neat! You can get heated solder suckers as well, which would fit right on, but my experience with normal vacuum desoldering stations is that the tips oxidize and dissolve, so replaceable tips are a must.
Maybe you should put in a bypass hole to keep the engine cool, that you could cover with a finger when you want full vacuum.
--chris
