Author Topic: Detect when DC motor is running?  (Read 957 times)
Offline Tom18991Topic starter
« on: December 06, 2023, 05:37:51 pm »
Looking for advice on how to detect if a DC motor is running, using only its ground wire? No current flows when the motor is off.   I'd like to create a yes/no binary signal I can feed to a microcontroller -- high when the motor is running, low when it is not.  Is there a tried and true way to do this?
Offline soldar
Re: Detect when DC motor is running?
« Reply #1 on: December 06, 2023, 05:41:44 pm »
No current is ever flowing on the ground wire. You mean "neutral"?
Online themadhippy
« Reply #2 on: December 06, 2023, 05:58:44 pm »
You mean "neutral"?
theres no neutral on DC
low side current sensors  and a comparator?
Online TimFox
« Reply #3 on: December 06, 2023, 06:06:27 pm »
Do you need to check that the motor is not stalled?
The current is higher than normal under stall conditions with power applied.
Offline soldar
« Reply #4 on: December 06, 2023, 06:13:08 pm »
You mean "neutral"?
I missed the DC part. My bad.
Offline Benta
« Reply #5 on: December 06, 2023, 06:58:25 pm »
A glass tube reed switch with a coil wound around it. That'll even double as noise filter.
Offline rcjoy
