Hello,
So I'm in process of building amplifier .... First brick would be a voltage regulator .... here one below , with trigger current protection ( when you crank it, amp will just turn off, a nice annoying feature
opamp : MC34071, Photocoupler PC817 (channels are independent and protection turn off a second ch over opto , psu dual, with equal VR, so VP then common ground)
board 1 channel:
trigger reaction on overload:
Questions:
Is the reaction time for triggering overload are sufficient (to avoid damage) ?
Is the way to improve the reaction time ?
any suggestion in overall ?
