Author Topic: smps hv spike problem  (Read 933 times)
Offline 5282Topic starter
« on: July 11, 2018, 07:02:13 pm »
i make some research on smps before i make on for 220v .
so i powered my transistor with only 5v and reduce all component value
the problem is in two things
1- high voltage spike on transistor collector  it's 50v and some time 30v and all this high voltage come from 5v suplly
2- the high high frequency switching around 500khz
here is the oscilloscope screen shoot  from transistor collector in attachment file
Offline Miyuki
  • Country: cz
    • Me on youtube
Re: smps hv spike problem
« Reply #1 on: July 11, 2018, 07:16:51 pm »
"simple" 50 years ago  ::) now with integrated power controller like TNY and similar is no reason to experiment with self oscilating flyback it is beast
waveform look ok for this type of circuit maybe snubber is not tuned right or use bad components
And how you probe it ? May be just ground lead induced noise
« Last Edit: July 11, 2018, 07:18:54 pm by Miyuki »
« Reply #2 on: July 13, 2018, 10:34:44 am »
thank you.
i found the problem . i must to put load in the transformer output. to reduce the reverse voltage from transformer .
.when i put the circuit in 220v the high reverse voltage kill the transistor. so i need load or feed back circuit
« Reply #3 on: July 13, 2018, 10:43:05 am »
here is my reverse voltage after i put load to transformer it's reduce from 50v to 12vpp. and i use good snubber circuit .
the oscilloscope screen in attachment
