I'm thinking about a USB charger that can be permanently installed in a car or motor home.
I want to minimise current draw while no USB device is attached. Tens of micro amps.
Perhaps by using a very low power circuit supplied by a linear regulator to disable the switching regulator when no device is attached. Id also like to include low input voltage shutdown, to avoid a flat car battery.
Is there a reliable way to detect when a USB device is connected while it is unpowered, without any mechanical switches?
