Transformer power is a square of the cross-section area of the inner leg of the EI core in cm^2. About 20% more for C core.
Square the area. 256VA
Measure the DCR of the primary, then double it
Two rules that I've used over the years are:
1. Load the output until the voltage drops by 10% from the no-load value. I think this rule came from a company that sold electronic surplus.
2. Measure the cross-sectional area of the core. Compare that to published data for similar transformers. I think this rule came from the ARRL.
If there's a disagreement between the two, take the smaller value.
Remember that transformers are rugged beasts. If you overload one slightly, it will just run a bit hotter.
Ed
Ed#1 isn't very good because larger transformers tend to have better regulation. Try that with a transformer rated to a few kVA and you will overload it!
Is this rule for 50 Hz? 60 Hz? 400 Hz?
Don't think I'll add this one to my tips 'n tricks, but if it works for you...
I don't think frequency is a factor in this one
So people building high frequency DC/DC converters to get the size of the magnetics down are on a wild goose chase? I don't think so.
My rules are intended for transformers like the one in Jester's photo. Most of us aren't interested in transformers rated for a few kVA.
Ed
