Author Topic: Auto powersave - How to retrofit on older KRK Rokit active monitor?  (Read 335 times)
Offline TinkeringSteveTopic starter
Helloooo,
an understandably sometimes hated feature of newer models of the KRK Rokit active studio monitor speakers is the auto-power-off when there is no input signal for 30min or so.
Here, someone modded his newer speaker to be able to (de-)activate it at will:
https://www.eevblog.com/forum/repair/krk-rokit-5-g3-how-to-permanently-disable-the-auto-power-off-feature/
Now, I won't  have it that easy, because my 2nd gen or so model does not have that feature, and I can't just bridge some IC ;)
How would you design a feature like that, to retrofit an older specimen with it?
My hobbyist tinkerer's first thoughts:
  • some power will always be drawn, to be able to auto-turn-ON also, by detecting a signal
  • unless..., then again, I wouldn't mind if it cannot do that and I had to press a button to re-enable
  • the latter would allow to save even more power, as no signal monitoring needs to go on, when it was switched off
  • i.e. in that case, a relay may cut mains power from the 3-contact mains jack - probably also the easiest point to intercept
  • do even small relays, and DC ones, hum, due to whatever miniscule instability in the setup? Perhaps using a mechanically latching relay is advisable? Although I reckon they may have fewer guaranteed cycles than non-latching ones
  • how/where to tap the signal in the chain for detection, without introducing noise?
  • is it too wild to assume the power supply in such a thing will have enough headroom to allow for the extra current draw of a relay? I think these still have analog amplifiers that draw a lot of current all the time, hence it seeming advisable to add this feature
  • signal dection/action could go like... comparator with certain threshold -> RC (dis-)charge for timing -> another comparator for disabling the power? (I normally just throw a cheap MCU at things, but it might add noise here :D )
