The thread about Cascode Amps got our
Curiosity going and just discovered (wife was going to toss them in trash) some notes that we can share, many can't be shared tho
Long ago starting round ~2004 we began looking into alternate means to create miniature Electronic Warfare Systems, these "Systems" would eventually evolve into single-chip solutions, EW SoC so to speak!!
Significant efforts were put forth to develop
Active replacements for the RF/MW/MMW combiners, splitters, mixers and so on that would cover ~DC to over 20GHz, later onto ~100GHz.
We began looking into core ultra-broadband amplifiers with controlled input and output impedances that could be altered into Active Input Combiners and Active Output Splitters, and later Active Mixers (later the PolyPhase Mixers were employed for many uses). Obviously for this effort to yield we needed to have good DR and low noise to replace the traditional components.
Initial work began with IBM SiGe BiCMOS processes (with plan to later into THz type InP) which supported SiGe BJTs over 300GHz Ft with 130 & 90nm CMOS. The core amplifiers were of the Cherry-Hopper origin that we added variable gain control by means bias current control. The designs are all Differential In/Out and utilized Quad Device & Layout Techniques to minimize process and temperature gradients.
1st is some quickly developed amplifier notes prepared back in March 2005 for some discussions & students. Note this is for a single ended version split in half by symmetry which made the analysis easier.
2nd is the test amplifier core, note the bandwidth peaking network at the top.
3rd/4th is the Gain control concept which is linear in dBV type control.
5th is the Gain Control schematic, note I1 and I2 for the core Amp.
6th/7th is response from 1Hz to 100GHz with AGC varied from 0 to 100ua.
8th is the Differential Input Referred Noise, note the 1/f characteristic on the left.
We also have some info on the Active Splitters/Combiners & Mixer if folks are interested.
Anyway, these were some of the core amp developments from back in 2004~5. These were fabricated in various SiGe BiCMOS processes and recall the tests performance was quite good, altho don't have any test data. Some fun stuff from way back then, and helped get our small research company acquired in 2006
Hopefully some folks may find these amplifier design concepts useful, they should apply equally well to any BJT, including the 2N3904 but with a much lower bandwidth.
Will try and answer any questions, if we can remember
Best,
