I have it running at 30.92V and 3.02A stable.
Mosfet case temp: 53 deg C.
heatsink temp (processor bottom) : 28 deg C.
resistor temp : ~ 28 deg C.
Fan: 12V DC
These cpu fans are a giant improvement , i ran into the limit of my power supply else i would have pushed it to 110 / 120 W .
The only thing that is acting up is the LM324N , it worked fine the first hour but it will only shoot up to the top rail now.
Things i did:
Replace the LM324N (several times)
check all the wiring (several times)
added pull down resistor at output of op amp
measured the output of the pot meter (no problems there)
Result: still a non working voltage follower opamp ...
Is the mosfet capacitance or something like that to high for the low power mosfet ?? i really don't know whats wrong :S .
I connected the opamp now in this weird way and it works. It only changes a a couple of 10 mA from 0-> 30V so it is still constant current.
pic:
Why is it working ?
if i pull out the wire of the feedback , the regulation wont work anymore and the mosfet will jump into saturation.
i also made a youtube video for you guys:
after the video i disconnected the fan to see how much it affects the heatsink temperature.
Within 2 mins the heatsink went to 40 deg. C. (almost the same as mosfet temp) and kept rising.
So i connected tge fan again and in 2-3 mins the heatsink went back to 29 deg. C. and the mosfet still at 40 deg. C. (normal) .
I did some calculations and the Artic freezer 7 pro rev 2 is : 0.21 deg C. / W (mosfet 0.75 + 0.25 deg c /w ) which makes it a total of :
1.21 deg C. /W
So i just tested a lead acid battery. I put my mosfet into saturation and you could immediatly see the disadvantage of using a 1 Ohm resistor at low voltages (10V) . I was limited to 7A @10.4A so i used one of my 3W 0.1 Ohm resistors i had laying around and i could get 20A + until the 10A fuse gave in my Rigol DM3058 (max 10A ) . i used my current clamp to measure the 20A + currents. I may make a relay or ssr in the final build so you can change from 1 Ohm 100W load resistor to a 0.1 Ohm 100W one. @ 20A i also saw some smoke coming from some of my leads , they were a bit thin.
yet another day has ended 52 minutes ago ... guess i'll get some sleep now.
gr. spikee
... still not asleep but i checked the fuse of my rigol dm3058 and it has blown indeed. Seems it will be my current clamp for now on.
