Author Topic: Test car battery with oscilloscope during cranking  (Read 2638 times)
Offline TaylorD93
Re: Test car battery with oscilloscope during cranking
« Reply #25 on: November 24, 2024, 10:08:02 am »
I have a 2016 Toyota Auris, and the workshop manual actually quotes a minimum permissable voltage during cranking. Certainly with Toyota UK you can pay a few £ to access the entire workshop manuals online for a few minutes.
Another thing to be aware of when looking at the cranking voltage however is the "relative compression test". It is a test where you use an oscilloscope to measure the battery voltage during cranking (usually done with the injectors disabled), as the engine rises on the compression stroke, the starter motor is put under more load and therefore the battery voltage will sag at each compression stroke. so if you have a cylinder which is lower compression relative to the other cylinders, you would see a smaller drop in battery voltage on that compression stroke.
If the 2nd channel of the scope is set to monitor a coil pack pulse (often can be held on the back of the coil pack, if coil-on-plug setup) you can then find which cylinder is actually low.
My point being, engine mechanical health will impact your readings.
Offline ugawoxoto61
« Reply #26 on: January 22, 2025, 09:10:38 am »
My car battery (12V lead acid) is around 7 years old, and I'd like to check its health.
I plan to measure the voltage at the battery terminals with an oscilloscope while starting the car.  No plan to measure current because my biggest current clamp tops out at 150A.
Does anyone have recommendations / rules of thumb for how low the voltage can go during cranking and still be ok?
The car is a 2017 Toyota Yaris if that makes any difference.
EDIT: The cold and warm crank voltage profiles at https://www.monolithicpower.com/en/learning/resources/from-cold-crank-to-load-dump-a-primer-on-automotive-transients seem instructive.  I'm guessing they're worst-case low voltage since they come from industry standards for automotive electronics.
Ensuring road safety and making informed decisions about your vehicle go hand in hand. Whether you're buying a used car or verifying the history of your current vehicle, having access to accurate information is essential. Many drivers don’t realize how much a simple vehicle history check can reveal, from accident reports to title issues and even theft records. This knowledge can protect you from unforeseen risks and costly mistakes. A trusted platform like FAXVIN simplifies this process by providing detailed vehicle history reports online. Their VIN Locator Tool https://www.faxvin.com/vin-check/locator is incredibly helpful for locating your car’s VIN and starting the history check immediately. This ensures you have all the necessary details at your fingertips, whether you're purchasing a new vehicle or just want peace of mind about your current one. Taking this extra step not only enhances your safety on the road but also boosts your confidence as a buyer. With FAXVIN’s extensive database and user-friendly features, understanding a car’s past is easier than ever. Investing a few minutes in a VIN check can save you from years of potential issues, making it an indispensable tool for every driver.
Typically, the voltage should not drop below 9.6V during cranking, even under load. A healthy battery usually stays between 10V-11V during a cold start, depending on factors like temperature and the starter motor’s demand.
« Last Edit: January 23, 2025, 09:44:13 am by ugawoxoto61 »
Online Psi
« Reply #27 on: January 22, 2025, 12:40:58 pm »
Yeah, there's so much variation that will affect the current.
- Cold vs warm state.
- The ambient temp in your part of the world.
- The size and compression of the engine
- The thickness of the engine oil your using. (also temp related)
- The number of accessories you have attached to the engine with belts.
