Author Topic: My first ever simple breadboard PSU  (Read 1370 times)
Offline antolancaTopic starter
« on: June 21, 2016, 08:52:49 am »
Hello EEVBlog.
Gonna build my first ever dual voltage PSU but would like your opinions on it.
On paper and simulated in Yenka it works. But in your more experienced view will it work?
Thanks in advance for any help.
Yesterday is yesterday. If we try to recapture it we will only lose tomorrow.
Online Ian.M
Re: My first ever simple breadboard PSU
« Reply #1 on: June 21, 2016, 09:05:27 am »
Totally useless.  The '5V' setting will output around 3.5V and the '3.3V' setting will output around 2.5V, sagging approximately 1V for every 3mA of load current!
If you are starting from a 5V USB charger, then all you need for the 5V setting is a 200mA polyfuse to provide over-current protection.  The 3.3V output needs a LDO regulator with decoupling caps as specified in its data sheet.  Use a SPDT center off switch at the OUTPUT to select the voltage 5V from before or 3.3V after the LDO regulator.
Also indicator LEDs go across the supply, with a current limiting resistor in series with the LED, *NOT* in series with the output!
« Last Edit: June 21, 2016, 06:31:05 pm by Ian.M »
Offline ZeTeX
  • Country: il
  • When in doubt, add more flux.
« Reply #2 on: June 21, 2016, 03:41:58 pm »
Get an adjustable low dropout linear regulator and be done with it - cheap, easy, and reliable and also adjustable voltage.
Online Alex Eisenhut
  • Place text here.
Offline dannyf
« Reply #4 on: June 22, 2016, 01:14:36 am »
If you are to use it to power very low load (a few ua for the lower one and a few ma for the upper one), it can be of some use.
Try to get a 3-terminal regulator and you can pretty much wire it up on the breadboard itself. Much simpler and far more useful than what you have here.
