Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Modular plugs and stranded/solid wire
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Modular plugs and stranded/solid wire (Read 639 times)
iXod
Frequent Contributor
Country:
on:
March 23, 2020, 02:17:17 am »
Years ago I would specify Ethernet 8P modular plugs for use with either solid or stranded conductors.
I look on Mouser now and using the parameter search, there's no filter for solid/stranded wire.
Have things changes such that present offerings can be used universally? Or...?
Thanks.
Logged
Monkeh
Super Contributor
Country:
Re: Modular plugs and stranded/solid wire
Reply #1 on:
March 23, 2020, 02:19:16 am »
There are some universal types (three prongs on the contact), but otherwise, still the usual split. Most don't know of it, doesn't surprise me Mouser don't have a filter for it.
Logged
iXod
Country:
Reply #2 on:
March 23, 2020, 02:37:44 am »
The few times I mentioned the fact (unique plugs for each wire type) I got blank stares.
One of those secret facts that probably causes lots of intermittent problems in the industry...
Logged
Monkeh
Super Contributor
Country:
Reply #3 on:
March 23, 2020, 03:04:25 am »
On a semi-related note, I've just discovered that these are a thing:
https://www.rdm.com/R-M-Products/Twisted-Pair-Cabling/FM45-Connectors-and-accessories/FM45-Cat.-5e-Connector-IP20-straight/Plug-FM45-Cat.5e-shielded-or-unshielded-AWG-23-to-26-IP20-568A-B-plastic-housing-R-M
Logged
ejeffrey
Super Contributor
Country:
Reply #4 on:
March 23, 2020, 02:47:26 pm »
There are some universal plugs, but stranded wire is by far the standard. Anything you get that doesn't specify you should assume is for stranded.
Field termination of plugs is also much less common than jacks. Normally you use solid wire for your horizontal run with jacks on both sides and premade stranded cables to connect to the switch and end device.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
