Author Topic: PCB USB PLUG  (Read 4759 times)
Offline wreeveTopic starter
    • embedded u systems limited
PCB USB PLUG
« on: September 11, 2015, 03:41:41 pm »
Has anyone got a design for a PCB footprint you can plug directly into a USB socket; I've seen a number in the wild, as a business card for instance, but I wondered if there is any specification (official or otherwise) on the pads and PCB thickness / dimensions which work reliably. Anyone ever done it?
Offline amyk
Re: PCB USB PLUG
« Reply #1 on: September 12, 2015, 03:24:36 am »
Look in the USB spec; I think I've seen the dimensions in there.
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: PCB USB PLUG
« Reply #2 on: September 12, 2015, 07:24:04 am »
Or just pull apart a USB plug and measure it.
Day Job: Mostly LEDs
Offline jc101
Re: PCB USB PLUG
« Reply #3 on: September 12, 2015, 07:54:57 am »
I've got an FTDI module which is just a bare board to plug into USB A sockets, the data sheet has some dimensions on it but not the pads themselves...
http://www.ftdichip.com/Support/Documents/DataSheets/Modules/DS_UMFT201_220_230XB.pdf
{Page 8}
Meaning the pads, and this will be approximate, the outside ones are 1.75mm x 11mm with the inside 1.25mm x 10mm.
Combine this with page 99 of the following and you should have all the dimensions needed to create a layout
http://www.usb.org/developers/docs/ecn1.pdf
Offline LukeW
Re: PCB USB PLUG
« Reply #4 on: September 12, 2015, 08:43:57 am »
Those Cypress CY8CKIT-049-42XX boards are super cheap, like $4 or something. So if you can't get the info from their open-source files you could always just buy one and measure it.
Also: https://github.com/freetronics/LeoStick
I just measured the thickness of a LeoStick and a Cypress PSoC board at the USB connector... they're 1.9mm.
