Hello all,
I've decided that it would be a good learning exercise to layout an active probe. The desired operating range would approximately be between 100kHz and 1GHz. The layout is pretty much complete, however, I do have a few uncertainties and questions.
Top layer:
Bottom layer:
1. Controlling impedance:
I had used saturnPCB's calculator to find the ideal width for a trace to have a line impedance of 50 ohms per manufacturing specs (0.6mm pcb thickness, 6 mil gap) for a coplanar waveguide. This gave me a trace width of about 25mils.
As a sanity check, does this width seem reasonable? I know over super short lengths (relative to frequency) it doesn't become that much of an issue, Just wanted to make sure.
Most PCB manufacturers offer the option to control trace impedance, is this entirely necessary considering that I have attempted to do that in the design? Does this just refer to materials used? Or will they modify the design to attain a 50 ohm impedance?
2. Problem areas:
There are a few problem areas that I have issues with. Following the signal path (black line), the first region selected by white are two parallel capacitors. Now, would the asymmetry in path lengths cause an issue for high frequency? (This also occurs on the input too) Would I need to length match due to potential phase shift? (Im asking for "from experience" cases, rather than purely mathematical)
Secondly, the trace for the OPAMP feedback and output (as highlighted by the second white region). Is it ok to run the feedback trace under the device? I know the substrate is tied to (AC) ground, so I only imagine extra parasitic capacitances to form rather than any issues re oscillation/stability.
For the bottom layer, is the star power distribution correct? I have both planes stitched as ground. Is it ok to place the decoupling capacitors on the bottom side?
3. Via stitching:
I know its ugly, but does it look sufficient? Would it cause any issues?
Also, I know the two pads at the input would act as parallel plate capacitors, the capacitance is large enough as such that it does not affect the design. They are intended for soldering probe pins/connections to.
Thanks for taking the time to read.
