Hi Folks,
This is my first post, I hope it makes sense.
I have some pre existing equipment that communicates bi-directionally over a differential pair via half duplex with RS485 devices.
My question is, how might I go about converting these devices to communicate wirelessly?
I have considered the 433MHz wireless modules because I have several spare, and the range required is not huge, maybe 10m (30') ish almost max.
I thought about brreaking into the non inverting (A) output of the 485 device and feeding that to my transmitter. Then using a (input common) non inverting and inverting buffer at the other end between the receiver to provide the inverted and non inverted inputs to the 485 chip. Here I would use two modules at differing frequencies for the differing transmission directions. However I found when I rigged this up without the wireless modules, just trying to use a single wire in place of the wireless the transmission could not be established.
Subequently, I have thought about using the inputs to the 485, DI, DE, RE| and RO and using these to drive my wireless modules. DE and RE| are supplied by the same pin of the uC, just operaing in complementary fashion, DI and RO each being attached to their own uC pins.
I propose to connect DI and RO to the relevant pins of my wireless modules and use DE to power the transmitters and RE| to control the power to the receivers, thus I will have bi-directional half duplex communication over the wireless modules. - Is this likely to work? I am not sure how the two devices will know how to toggle the state of their enable pin.
Can anyone out there confirm that my ideas might work, or have a better idea as to how I might achieve my goal?
Regards,
Brett.
