Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Pin 1 of AMPMODU II
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Pin 1 of AMPMODU II (Read 749 times)
ricko_uk
Super Contributor
Country:
Pin 1 of AMPMODU II
on:
April 17, 2020, 07:08:41 pm »
A bit of a silly question but I looked at all datasheets I could find of TE AMPMODU II connector and none seem to specify Pin 1 and neither does the 3D module nor in the mating physical part which I have. That is strange given that it is a polarised connector. It is not that important but I like to keep everything as standard as possible.
With reference to the attached picture which would be pin 1? Most likely B or D, but which one?
Thank you
Last Edit: April 17, 2020, 09:14:35 pm by ricko_uk
Logged
HwAoRrDk
Super Contributor
Country:
Re: Pin 1 of AMPMODU
Reply #1 on:
April 17, 2020, 08:16:28 pm »
What's the part number?
The part drawings usually have pin 1 marked, like for example this:
Logged
ricko_uk
Super Contributor
Country:
Reply #2 on:
April 17, 2020, 09:14:13 pm »
Thank you HwAoRrDk,
I just noticed I initially wrote AMPMODU instead of AMPMODU II. The part number is AMPMODU II - 280384-2.
Your screenshot does not look like the AMPMODU II series (it doesn't seem to have the side walls). Is that perhaps some other AMPMODU series?
Thank you
Last Edit: April 17, 2020, 09:15:58 pm by ricko_uk
Logged
HwAoRrDk
Super Contributor
Country:
Re: Pin 1 of AMPMODU II
Reply #3 on:
April 17, 2020, 09:27:41 pm »
That was just a random AMPMODU part, because I know I had seen pin 1 notes on drawings for that series before.
But it's curious that the drawing for that specific part doesn't have it.
I suppose you'll just have to go on how other similar parts are numbered.
Logged
ricko_uk
pigrew
Frequent Contributor
Country:
Reply #4 on:
April 17, 2020, 09:36:12 pm »
I've seen cases like this where there is no answer, it's up to the engineer.
However, it seems like there is an answer for this product. The "mating connector" 280365's drawing shows "pin 1" labeled on one corner.
The answer is D?
Logged
ricko_uk
donotdespisethesnake
Super Contributor
Country:
Embedded stuff
Reply #5 on:
April 17, 2020, 10:27:33 pm »
You still have to be careful, some Molex connectors have pin 1 marked on the male and female parts, but for different position. Caused an interesting cockup in a prototype - each party concerned claiming they had correct pin out.
Logged
Bob
"All you said is just a bunch of opinions."
ricko_uk
ricko_uk
Super Contributor
Country:
Reply #6 on:
April 18, 2020, 12:25:24 am »
Thank you all
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Pin 1 of AMPMODU II
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
