Hi
I've recently purchased a Rhom BM92A12MWV-EVK-001 Power delivery dev board for examination. I also bought an Inatech 45W USB power supply which has PD3 capabilities. The Inatech has a plastic earth pin (in the UK) and is double insulated. When I connect the Rhom board to the Inatech, I measure open between the live and the output +V and gnd, and also with the neutral to +V and gnd.
However, when I attempt to examine the output with my scope, I notice that a tiny spark appears when I connect the gnd lead of the scope probe to gnd on the dev board. This seems quite bad, what am I missing here?
I've done some tests and the scope seems to have survived, but I'd rather double check what is causing this before continuing.
