I've never used EasyEDA but it looks like the layout is not finished yet ! The ratline shows that GND is not routed. Did you add a ground plane that is not displayed here ?
On the schematic, is L1 wired as it should ? Did you check the power rails voltage ?
Wiring around LM2596S-ADJ should be cleaned up (rearranged) so errors could become obvious...
