Author Topic: What resistance is a 0m30 shunt resistor?  (Read 1218 times)
Offline Alex_BakerTopic starter
« on: June 03, 2023, 07:01:03 pm »
Hello, quick question here!
I am designing a current sense circuit and referencing other designs. I keep seeing shunts marked 0m30, what resistance is this? I have had trouble finding resources to figure out what code this uses. My guess is that this is 3 miliohms, but I am not 100% sure.
Thanks!
Offline Dave
  • Country: si
  • I like to measure things.
Re: What resistance is a 0m30 shunt resistor?
« Reply #1 on: June 03, 2023, 07:55:53 pm »
0.3 milliohms or 300 microohms.
You will often find the unit prefix used in place of the decimal point in electronics, be it on schematic diagrams, PCB silkscreens, or on the components themselves.
Supposedly it originates from the time when schematic sheets were hand drawn and copied back and forth. Degradation of image quality meant that decimal points had a tendency of disappearing, so the simple solution was to avoid using them entirely.
« Last Edit: June 03, 2023, 08:02:23 pm by Dave »
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
« Reply #2 on: June 03, 2023, 08:53:06 pm »
Cool, Thanks!
Offline DavidAlfa
« Reply #3 on: June 03, 2023, 09:28:28 pm »
Can you really handle 300uOhm accurately?
I mean, even the solder will affect the value at such low value.
Offline langwadt
« Reply #4 on: June 03, 2023, 09:33:26 pm »
at such low values, hopefully, the resistor and footprint has a kelvin connection for the sense
Offline coppice
« Reply #5 on: June 03, 2023, 09:39:47 pm »
Most of the applications for such low value resistors are as current sensing shunts. The accuracy of the resistance is frequently not that important, as there will be a calibration performed after assembly. Many times such low resistances will be 4 terminal, but 2 terminal ones are very common, as they are cheaper. The key issue is not solder, but copper in the sensed path. Its awful temp coeff (0.4%/C) ruins any calibrated accuracy over even a modest temperature range.
Offline Benta
« Reply #6 on: June 03, 2023, 09:44:32 pm »
Is this for a 1000 A current shunt?
Offline coppice
« Reply #7 on: June 03, 2023, 09:48:31 pm »
You would generally use a much lower resistance for 1000A. 300 micro-ohms will dissipate 300W.
Offline langwadt
« Reply #8 on: June 03, 2023, 10:09:12 pm »
most metals are roughly 0.4%/C
Offline Zero999
  • 0999
« Reply #9 on: June 03, 2023, 10:25:29 pm »
I would use a Hall effect sensor for 1000A.
300µOhm is fine for up to 100A or so. The source impedance is low, so it doesn't matter if the amplifier has a low input impedance and relatively high bias currents, making low offset easier to design, or use a chopper amplifier.
Offline coppice
« Reply #10 on: June 03, 2023, 11:08:33 pm »
True, but follow the guidelines in https://www.analog.com/en/analog-dialogue/articles/optimize-high-current-sensing-accuracy.html and the metals with a horrible coefficient can have a minimal effect. The contacts on the resistor itself should be made of a material with a good coefficient.
