Author Topic: Dimmer for an aspirator (evaporative cooler)  (Read 858 times)
Offline woor90Topic starter
« on: May 11, 2019, 08:31:21 pm »
Hello,
I have an evaporative cooler which is too noisy for the application I want to use it for, I'd like to ask if it's possible to use a dimmer for it in order to drastically reduce the noise. Of course I'm aware that decreasing the fan speed will decrease the efficiency of the device, but this is not a problem at all, it's already oversized. My issue is only the noise (around 60dB at minimum...).
In particular I'm talking of this device:
https://www.honeywellstore.com/store/products/evaporative-air-cooler-for-indoor-outdoor-and-commercial-honeywell-co60pm.htm
I know there is also a water pump inside, but I can simply disconnect it and run it separately.
Do you think it's a feasible workaround?
Will decreasing the speed to 1/2 or 1/3 of the selectable lowest speed significantly decrease the noise?
Which type of dimmer do I need? one for induction motors, right?
Thanks
Offline soldar
Re: Dimmer for an aspirator (evaporative cooler)
« Reply #1 on: May 11, 2019, 09:00:08 pm »
The description says it has three speeds. Even the lowest is too noisy for you?
« Reply #2 on: May 11, 2019, 09:40:32 pm »
Yes, it's too lout even at low speed.
Offline NiHaoMike
    • Facebook Page
« Reply #3 on: May 12, 2019, 01:12:30 am »
Get a ceiling fan speed controller.
Offline soldar
« Reply #4 on: May 12, 2019, 06:20:03 am »
While an electronic controller might work you could try something simpler which is inserting a resistor in series (suitably sized in every respect).
