Hello All,
I am trying to understand the operation of a two stage open loop comparator.
In the attachment is the output stage of the two stage comparator, a current-sink inverter.
What my question is, is how do I know that the output voltage can go to Vss in the low state. To me, it would seem like if Vo dropped to Vss in its low state then transistor M7 would no longer be in saturation mode(possibly triode mode) and I am not sure what this means for the operation of the circuit.
I've also tried looking at this from the approach of transistor M6. The maximum that Vg6 can be is Vdd-|Vtp| in order to maintain M6 turned on. I wasn't able to develop this thought any further.
My thoughts are that the Vo can't drop to Vss, rather it can drop to (Vgs - Vt) above Vss and maintain saturation of M7. The book says that this voltage can drop to Vss though which confuses me.
Any help in understanding is appreciated. Sorry about the slanted image.
This circuit is from CMOS Analog Circuit Design by PE Allen, page 450, Figure 8.2-1.
Thanks,
Melvin
