Author Topic: Diode vs BJT temperature sensors  (Read 6596 times)
Offline philpemTopic starter
  • That Sneaky British Bloke
« on: November 01, 2013, 02:56:05 pm »
Hi there,
In one of my fits of insanity, I decided it'd be fun to try and build a laser power meter. What I have is a thin chunk of brass, painted black on one side, with a 100R resistor and some form of temperature sensor with sub-degree-C resolution. A second sensor is held at room temperature and used to eliminate ambient temperature from the equation (zero the measurement). An instrumentation amplifier, precision current source (the good old REF200) and "balance" pot (used to compensate for Vf/Vbe difference between the two sensors by adjusting the forward current) completes the circuit.
The theory is, the black paint absorbs the energy from the laser beam and its temperature rises as a result. Measuring the increase in temperature allows you to work backwards to calculate optical power. The 100R resistor can have a known power (say, 10mW DC) fed through it to "calibrate" the sensor head.
I've noticed that there are two ways to implement a "silicon bandgap" temperature sensor -- a silicon diode (e.g. 1N4148) or a diode-wired bipolar transistor (e.g. 2N3904, BC547). The BJT seems to be more prevalent. What I'm struggling to find is any rationale behind this; a lot of silicon temperature sensor chipmakers say "always use a BJT", but give no reason for the statement.
Does anyone know why you'd use a diode-connected BJT? Are they more accurate or repeatable than silicon diode sensors?
Cheers,
Phil.
Phil / M0OFX -- Electronics/Software Engineer
"Why do I have a room full of test gear? Why, it saves on the heating bill!"
Offline edavid
Re: Diode vs BJT temperature sensors
« Reply #1 on: November 01, 2013, 03:43:22 pm »
You wouldn't want to use a 1N4148, since it's gold-doped.  I don't know if that explains the transistor preference or not.
Online Andreas
« Reply #2 on: November 01, 2013, 04:12:18 pm »
http://cds.linear.com/docs/en/application-note/an137f.pdf
see page 6
usually you would want to use a PNP transistor.
With best regards
Andreas
Online wraper
  • Country: lv
« Reply #3 on: November 01, 2013, 04:30:55 pm »
Better use PT100 or PT1000 sensor if you want reliable "sub-degree-C resolution".
Offline muvideo
« Reply #4 on: November 01, 2013, 05:40:56 pm »
I would consider also using a simple NTC, a good one it's repeteable enough,
coupled to a good resistor I think it's the simplest and cheapest way to have
an high resolution temperature sensor.
Fabio Eboli.
Online wraper
  • Country: lv
« Reply #5 on: November 01, 2013, 05:57:11 pm »
Why to bother, when for $6-7 you can get PT100 class b, completely linear, with 0.4 degrees C initial resistance accuracy at room temperature. 0.05% stability. You even don't need to do calibration in many cases.
http://www.micropik.com/PDF/pt100.pdf
http://www.farnell.com/datasheets/1702835.pdf
« Last Edit: November 01, 2013, 06:04:16 pm by wraper »
Offline Eviltech
« Reply #6 on: November 01, 2013, 06:55:02 pm »
What i use for a sub-degree temperature sensor is a NTC from a digital thermometer for medical pourposes. If you use a verry stable power supply you might even get to 0.01C accuracy. Downside is that the particular NTC is only usable up to about 80 deg. Celsius.
Online wraper
  • Country: lv
« Reply #7 on: November 01, 2013, 07:30:24 pm »
I have calorimeters at work which uses PT100, resolution is 0.0001 C (on display, actually uses precision 24bit ADC) C and at least 0.0003 C is usable.
« Last Edit: November 01, 2013, 07:33:55 pm by wraper »
Offline Eviltech
« Reply #8 on: November 01, 2013, 07:40:28 pm »
I do belive this will be perfectly adiquate, presuming the rest of the circuit is up to the task... :)
