Author Topic: Dip Accelerometer  (Read 5821 times)
Offline House91320
Dip Accelerometer
« on: October 14, 2010, 03:44:59 am »
Dose any one know if any companies make a dip accelerometer.
Offline DJPhil
Re: Dip Accelerometer
« Reply #1 on: October 14, 2010, 04:53:40 am »
I think Freescale used to, I remember attempting to salvage a dip accelerometer a while back but I don't remember who it was from. I'm ashamed to say that the desoldering operation was a failure, as I was just learning then, so I wound up tossing it. A quick spin through digikey and it looks like they're all ultracompact smd footprints nowadays. :(
Offline sonicj
  • updata successed!
« Reply #2 on: October 14, 2010, 05:05:05 am »
not to my knowledge...
sparkfun offers a wide variety in prototyping friendly form. link
Offline fsleeman
« Reply #3 on: October 25, 2010, 05:49:51 pm »
I personally have never seen one. Digikey has carried LCC-8 accelerometers which you can hand solder, although they are kind of a pain.
Offline tecman
« Reply #4 on: October 25, 2010, 06:27:56 pm »
Analog Devices has a nice selection of accelerometers.  Check them out.
paul
Offline House91320
« Reply #5 on: November 06, 2010, 05:35:00 am »
I have some AD accelerometer and there are almost imposable to use. :'(
Offline ddrl46
« Reply #6 on: November 12, 2010, 12:05:23 pm »
Never seen one unfortunatly.
Offline hans
« Reply #7 on: November 12, 2010, 09:03:02 pm »
Realize that accelerometres are being put in these special packages for mounting considerations (a DIP in a socket isn't fixed and isn't levelled) and also because they are quite modern technology to work with. Your best bet would be a prototype extension, but don't expect the best level of accuracy because of small variations you will get from the connection headers.
However, if you got a very steady hand (or don't drink coffee before you start soldering) you could try to glue the IC properly on a board, upside down and then solder each wire to the leadless pin. It's not ideal, not sturdy , not proffesional, and maybe same functional as the prototyping solutions, but it might work for simple purposes so you can use every type of chip you want.
Offline tinsmith
« Reply #8 on: November 19, 2010, 08:10:50 am »
The leveling of a DIP part isn't as important as you'd think.
What exactly are you trying to do? If space is unimportant, you could always repurpose a Wii Nunchuck. They be cheap as well.
Offline technovm
« Reply #9 on: November 21, 2010, 03:25:57 pm »
You can also check out ST
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #10 on: November 22, 2010, 01:05:58 am »
why the hassle with branding? here is alot http://cgi.ebay.com.my/3-Axis-low-g-Accelerometer-MMA7260-prototype-PCB-/250727472307?pt=UK_BOI_Industrial_Automation_Control_ET&hash=item3a60859cb3 my main point is not the specific brand, but the adapter.
Offline House91320
« Reply #11 on: November 26, 2010, 09:08:12 am »
well i cant get dip but can i get so
